Running a command in CMD doesn't work
pancakegh
Post by pancakegh »
I'm trying to run a CMD command to batch render a bunch of scenes in blender.
I'm testing if the command line task works. I input the following:
this command keeps running and nothing happens.
If I open cmd in windows and input the same parameters it opens the blender folder in explorer.
Any idea how to get this working?
Re: Running a command in CMD doesn't work
Put the /c parameter at the beginning of parameters.
If you use CMD.EXE you have to use this command line:
cmd.exe /c <your_command_line_string>
/C - Carries out the command specified by string and then terminates
To get more command-line options of CMD.exe use
cmd /?
also look at the Change Folder action
It changes the current folder without problem
