Scheduler Not Working
stevens
Post by stevens »
Hello, I'm running RoboTask 6.2 on Windows 7 sp1. I created a task which ran the scheduler ok. We were not using this task and so we abandoned it. A few months ago we when back to using this task but the scheduler will not run. I can run the task manually but each time I set the scheduler to run it fail. Do you have any solutions to try? Thanks
Re: Scheduler Not Working
Try to re-create this trigger. This is not a very difficult
remove the trigger and create it again with same parameters.
There was a problem with trigger's IDs in old version. We have fixed this later.
