Printing problem
marcolobaido
Printing problem
Post by marcolobaido »
Hi, I try to print a file with several printers but robotask gime me an error:
"no application is associated with the specified file for this operation."
Which application I need to associate?
marcolobaido
Re: Printing problem
I solved associating Adobe Reader to the pdf extention and it works. I used Microsoft Edge. I hope it can be useful.
RoboTask doesn't print documents directly. It uses the default application for this.
It is in the description of Print document action
To print a document, the Print Document action uses a default application for the specified kind of documents. For example, for a Word document (DOC file) it is usually the MS Word from the MS Office package, for a PDF file it is the Acrobat Reader, etc.
The action can direct a document to any printer registered in the system. Of course, the default application is supposed to support printing on the specified printer. As a rule, all the basic applications support this function.
It seems you try to print some PDF document. In this case you have to install Acrobat Reader or Foxit Reader to process your documents
