i need help to CREATE FOLDER action
guillermo
Post by guillermo »
Hello i need help to create a task for next action:
Action Create folder : example
1. input folder/siemens_3223_01.pdf, siemens_3223_02.pdf, siemens_3223_03.pdf
2.Wach for files
3. Create a new folder: input folder/siemens_3223/siemens_3223_01.pdf, siemens_3223_02.pdf, siemens_3223_03.pdf
if you can helpme i will very happyy jaja
Guille
Re: i need help to CREATE FOLDER action
Yes, of course this is possible
Look at the task below;
CatID=INTEGER|1040932817
ExternalName=STRING|"Task311"
ID=INTEGER|-68798012
Name=STRING|"sort files"
Name=STRING|"Create local variable ""IN_FOLDER"" with value ""D:\input folder"""
varname=STRING|"IN_FOLDER"
varvalue=STRING|"D:\input folder"
Name=STRING|"File Loop"
date1=STRING|"20170913"
date2=STRING|"20170913"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"{in_folder}\*.pdf"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
ActionID=STRING|"A_STR_POS"
Name=STRING|"STR Pos"
from=STRING|"1"
search=STRING|"_"
source=STRING|"{ExtractFileName({filename})}"
variable=STRING|"p"
Name=STRING|"STR Extract"
amount=STRING|"{p}"
from=STRING|"1"
variable=STRING|"nam"
ActionID=STRING|"A_STR_BETWEEN"
Name=STRING|"STR Between"
begin=STRING|"_"
end=STRING|"_"
save=STRING|"0"
startpos=STRING|"1"
variable=STRING|"num"
Enabled=INTEGER|0
Name=STRING|"Show ""{FileName}"""
msg0=STRING|"{FileName}"
msg1=STRING|"{nam}"
msg2=STRING|"{num}"
msg3=STRING|"{p}"
msgcount=STRING|"4"
Name=STRING|"Set variable ""NEWFOLDER"" with value ""{in_folder}\{nam}{num}"""
varname=STRING|"NEWFOLDER"
varvalue=STRING|"{in_folder}\{nam}{num}"
Name=STRING|"Create Folder ({NewFolder})"
newfolder=STRING|"{NewFolder}"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"{NewFolder}"
f_count=STRING|"1"
file0=STRING|"{FileName}"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"1"
rename=STRING|"0"
renamemask=STRING|"*.*.new"
subdir=STRING|"0"
system=STRING|"1"
I creates the folder D:\input folder
Initial stat of the folder:
 Directory of D:\input folder
13.09.2017  16:12    <DIR>          .
13.09.2017  16:12    <DIR>          ..
13.09.2017  15:59                 0 motorola_3571_01.pdf
13.09.2017  15:59                 0 motorola_3571_02.pdf
13.09.2017  15:59                 0 motorola_3571_03.pdf
13.09.2017  15:59                 0 siemens_3223_01.pdf
13.09.2017  15:59                 0 siemens_3223_02.pdf
13.09.2017  15:59                 0 siemens_3223_03.pdf
               6 File(s)              0 bytes
The status after execution of the task
13.09.2017  16:16    <DIR>          .
13.09.2017  16:16    <DIR>          ..
13.09.2017  16:16    <DIR>          motorola_3571
13.09.2017  16:16    <DIR>          siemens_3223
               0 File(s)              0 bytes
 Directory of D:\input folder\motorola_3571
               3 File(s)              0 bytes
 Directory of D:\input folder\siemens_3223
               3 File(s)              0 bytes
     Total Files Listed:
               6 File(s)              0 bytes
I hope I understood your job correctly
guillermo
Post by guillermo »
ok thanks works in lite version?
Unfortunately this task will not work in lite version.
RoboTask Lite doesn't contain Loops & Flows actions (File Loop) and String actions (STR Pos, STR Extract, STR Between)
Look at full feature table here, please: http://robotask.com/lite_vs_full/
