Select several files
marcolobaido
Post by marcolobaido »
Hi, I use the "open dialog" action to select a file and attach it in a mail but I can select only one. How can I select more files?
Re: Select several files
Maybe we need to add the feature to select several files.
Now you can use this algorithm (see task below)
You can select several files on-by-one. To stop selection just press Cancel on the open dialog.
ExternalName=STRING|"Task303"
ID=INTEGER|1272630076
Name=STRING|"open several files"
Name=STRING|"Create local variable ""LIST"" with value """""
varname=STRING|"LIST"
Name=STRING|"While loop"
value1=STRING|"True"
Name=STRING|"Open Dialog"
caption=STRING|"Open File"
default=STRING|"None"
variable=STRING|"FILENAME"
value1=STRING|"{FileName}"
value2=STRING|"none"
Name=STRING|"Break"
Name=STRING|"Set variable ""LIST"" with value ""{List}{FileName}{EOL}"""
varvalue=STRING|"{List}{FileName}{EOL}"
Name=STRING|"Show ""Selected files:"""
msg0=STRING|"Selected files:"
msg1=STRING|"{List}"
msgcount=STRING|"2"
marcolobaido
Thank you very much. It would be a very useful action.
Next version contains modified Open dialog.
You can download already,
