Search function with symbols?
pancakegh
Post by pancakegh »
I made an action which lets you input a string. For every .pdf file in a certain map which contains the string, it will append the path to the file inside a text file. At the end of the loop it will open the text file wich contains the path to all the .pdf's containing the string. For some reason it will not show the following file (which contains a hyphen):
AIH-710060 Folder Pronto.pdf
Does anyone know why it can't see that certain file?
Re: Search function with symbols?
It would be great if you send this file and your task to me for investigation (to oleg(at)robotask.com)
Maybe you made some mistake.
pancakegh
Post by pancakegh »
Hello Oleg,
I have sent you an e-mail with my action.
Already answered
It works! Look at the video: https://youtu.be/N5YVMCcqmMM
I changed your task for my environment. See below.
ExternalName=STRING|"Task103"
ID=INTEGER|2041522328
Name=STRING|"Zoek PDF in Product layouts (changed)"
Name=STRING|"Input Box"
password=STRING|"0"
prompt=STRING|"Zoek .PDF in Product layouts"
variable=STRING|"ZOEKEN"
Name=STRING|"Run ""designnummers.txt """
ifnonzero=STRING|"0"
program=STRING|"{tempDir}\designnummers.txt"
runas=STRING|"0"
wait=STRING|"0"
operator=STRING|"7"
value1=STRING|"{ZOEKEN}"
ActionID=STRING|"A_FLOW_EXIT"
Name=STRING|"Exit"
Name=STRING|"Create text file {tempDir}\designnummers.txt"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"{tempDir}\designnummers.txt"
linecount=STRING|"0"
suppress=STRING|"0"
Name=STRING|"File Loop"
date1=STRING|"20170103"
date2=STRING|"20170103"
destvar=STRING|"ZOEKRESULTAAT"
DuringMinutes=STRING|"1"
file0=STRING|"D:\Temp\pdf\*.pdf"
searchkind=STRING|"0"
sort=STRING|"1"
sortby=STRING|"0"
sortorder=STRING|"1"
subdirs=STRING|"0"
timesize=STRING|"0"
operator=STRING|"6"
value2=STRING|"{ZOEKRESULTAAT}"
encode=STRING|"0"
fileexists=STRING|"1"
line0=STRING|"{ZOEKRESULTAAT}"
suppress=STRING|"0"
UniqueID=INTEGER|1550354123
hotkey=STRING|"57465"
I have changed folders names. Also I created the file with name AIH-710060 Folder Pronto.pdf
It works. It seems the problem somewhere else... Maybe the file has some attributes or secure parameters
Also I tested for string "AIH-710060". It works.
pancakegh
Post by pancakegh »
Thanks!
Ugh, I'm so stupid.. Turns out that the pdf was actually in a subfolder, and include subfolders was unchecked :roll:
