Hi, I don't succeed to close a window using window command. The log says 1 window processed.
I have this problem only with this window.
Window not closed
marcolobaido
Window not closed
- Attachments
- Cattura.PNG (17.9 KiB) Viewed 9091 times
Re: Window not closed
Some windows has non-standard handler of this commend.
For example you can't close RoboTask's main window by standard method too.
The log message said that RoboTask has found the window and send the command to it.
