Shortcut key combination not inserted
Hey Oleg,
In a task I need to add a column in Excel. The shortcut for this is Ctrl+Shift+Plus. (See https://exceljet.net/keyboard-shortcuts/insert-columns). Although the keystroke window recognises the combination, he doesn't add it into the field. Please try it yourself.
I solved it in another way, but I just wanted to let you know.
Re: Shortcut key combination not inserted
Thanks. We'll fix this
Use the string ^(+(=)) for this combination.
