Time in 24h format
marcolobaido
Time in 24h format
Post by marcolobaido »
Hi, I need to set an excel cell with a 24h time (15:30) but when I open the excel file it's written as 3:30:00 PM.
I had this problems with dates but I solved using DateTimeToFormat variable and it works.
Is there a way to impose also the 24h time format?
Re: Time in 24h format
It seems the system date-time format is set to "American format" on your computer.
So Excel shows date-time values in default format in your system.
In order to transform to 24h format use the same function: DateTimeToFormat
Use the expression: {DateTimeToFormat({Time},hh:nn:ss)}
If you want to suppress seconds: {DateTimeToFormat({Time},hh:nn)}
marcolobaido
Ok...I solved the problem:
I created a model file setting cells with format "personalized" "dd/mm/yyy or hh:mm etc...". Then I set cells with robotask without choosing the format and it works.
aa1508
Post by aa1508 »
would you please add an example on how to convert the 0.58333333333 (time extracted from excel) to 2:00 pm?
thank you
Look at my example below
CatID=INTEGER|1251730006
ExternalName=STRING|"Task187"
ID=INTEGER|-756587506
Name=STRING|"Set variable ""REALVAL"" with value ""0.58333333333""..."
Name=STRING|"Set variable ""REALVAL"" with value ""0.58333333333"""
varname=STRING|"REALVAL"
varvalue=STRING|"0.58333333333"
Name=STRING|"VB Evaluate"
expression=STRING|"cdate({RealVal})"
linecount=STRING|"0"
loadfromfile=STRING|"1"
variable=STRING|"TimeVal"
Name=STRING|"Show results"
msg0=STRING|"{RealVal}"
msg1=STRING|"{TimeVal}"
msg2=STRING|"{DateTimeToFormat({TimeVal},hh:mm:ss am/pm)}"
msgcount=STRING|"3"
