Hi, I want to compare two numbers extracted from excel choosing the bigger:
I create the global variables with initial value = 0
I extract cell with numeric value
if
{ore_corso} > {ore_corso_ps}
then
set {ore_corso_ps} with value {ore_corso}
at the end my global variables result for example:
{ore_corso} = number
{ore_corso_ps} = {ore_corso}
is it my fault?
Problem with variable (bug?)
marcolobaido
- Attachments
extract in your desktop.rar- (7.53 KiB) Downloaded 1377 times
Re: Problem with variable (bug?)
Look at the step #10.
The problem is here (see screenshot) Turn ON this checkbox, please.
When it is ON the action expands the expression and next assigns the result to variable.
When it is OFF the action assigns the expression as-it-is
marcolobaido
Thank you, also this time it was my fault
