Excel Pivots
crotalus
Excel Pivots
Post by crotalus »
Dear All,
sre Excel pivots and query to external data already supported in Robotask?
Best regards
Re: Excel Pivots
Unfortunately not.
RoboTask contains the most popular functions for Excel:
  • Get cell value
  • Set cell value
  • Save document
and others
You can use VB script or macrorecorder in Excel application to make more complex automation of Excel document.
Excel macrorecorder creates the macro as VB script in the document.
You can use this script as template for your own script.
bestazy
Re: Excel Pivots
Post by bestazy »
Hello!
I'm attempting to automate something for the first time, and I need some help. This doesn't /need/ to be in RoboTask, but it does have to be in a free automation tool.
I need RoboTask to go to Excel and copy the data in A1. Then I need to have it switch to a proprietary program and paste A1 contents into a field and hit Enter. I've gotten that far with the record macro option. After this point, RoboTask needs to find a certain text string in the program, and print the page on which it appears and any subsequent pages.
Then I need it to return to Excel, move down a cell and repeat the macro. Preferably, I would like it to continue this process until it reaches an empty cell, at which point the task would end.
I've managed to get 1/3 of this macro done, but I'm at a standstill concerning how to find the string and how to move the macro down a cell. Any advice? Thanks!
Re: Excel Pivots
Look at the example how to process column until the empty value
CatID=INTEGER|2091586075
ExternalName=STRING|"Task302"
ID=INTEGER|1490976608
Name=STRING|"process column in Excel"
Name=STRING|"Set variable ""ROW"" with value ""1"""
varname=STRING|"ROW"
varvalue=STRING|"1"
filename=STRING|"D:\Temp\test.xls"
hide=STRING|"0"
mode=STRING|"0"
Name=STRING|"Set variable ""CELLVALUE"" with value ""begin"""
varname=STRING|"CELLVALUE"
varvalue=STRING|"begin"
Name=STRING|"While loop"
operator=STRING|"8"
value1=STRING|"{cellValue}"
ActionID=STRING|"A_EXCEL_GET"
Name=STRING|"Excel Get Cells"
cell00000000=STRING|"R{row}C1"
var00000000=STRING|"CellValue"
worksheet=STRING|"1"
operator=STRING|"8"
Name=STRING|"Show ""{CellValue}"""
msg0=STRING|"{CellValue}"
Name=STRING|"Increment variable ""row"""
incement=STRING|"1"
vaiable=STRING|"row"
Re: Excel Pivots
...needs to find a certain text string in the program...
...how to find the string...
Where do you want to find some string?
You easily can check the existence of some string in text (text file or text in variable).
But I think that you mean something else.
