Any way to increase text size ?
User avatar
robotask
Post by robotask »
When creating or editing tasks, is there a way to increase font/text size ? It is also very hard to read the task name(s) list, again, due to text size.
Thank you
Re: Any way to increase text size ?
RoboTask uses system default font and default size of font.
You can increase the size of system fonts for all applications.
bgregory
Post by bgregory »
I asked this awhile back and you gave me the same reply. I don't WANT to change the system wide font size. We should be able to adjust
the fonts within the program. They are just too small.
Unfortunately RoboTask has no function to change own fonts dynamically
New version already contained "Scale" function. Menu Options->Scale
You can download already
bgregory
Post by bgregory »
Thank you Oleg for the font scaling. Very much appreciated.
Bob Gregory
