Print from command line - File Associations PDF
mploug
Post by mploug »
Is it possible to make Print from command line - File Associations (PDF)
work with Adobe Reader, Foxit Reader and other PDF readers
as well?
See:
http://robotask.com/forum/viewtopic.php ... tion#p6069
So far, we only succeed in making it work with sumatra PDF.
Thank you in advance.
Kind regards,
Martin
Re: Print from command line - File Associations PDF
Adobe reader is anther software product
It seems to print file it uses the command line:
AcroRd32.exe /t <filename> <printername> <drivername> <portname>
read more here please: http://stackoverflow.com/questions/6191 ... -reference
Another readers may have another command line options. It's necessary to read corresponding documentation
