Save XML
dj.funny
Save XML
Post by dj.funny »
Dear readers,
I use Save XML to make a XML-file.
From this I want to make the XML
<voorraad><item><artikel>POST</artikel><aantal>-4</aantal></item><item><artikel>RING N&S</artikel><aantal>0</aantal></item><item><artikel>SC1911-117</artikel><aantal>0</aantal></item><item><artikel>SC1911-330</artikel><aantal>0</aantal></item></voorraad>
But each time there is an error: It is (I'll think) because off the & sign
How to solve this??
In the help file is the following: Automatically converts non-ASCII symbols into the UTF8 format.
When I skip the
part the XML is made correct
Is there another way to do this?
Re: Save XML
Replace the string RING N&S with string RING N&S
The character & (ampersand) is a reserved symbol in XML format. It used for special constructions.
Try my example below:
CatID=INTEGER|263000617
ExternalName=STRING|"Task73"
ID=INTEGER|490811654
Name=STRING|"Test XML with ampersand"
ActionID=STRING|"A_XML_CREATENODE"
Name=STRING|"XML Create Node ""node1"" and save to ""aaa"""
attcount=STRING|"0"
name=STRING|"node1"
txt00000000=STRING|"RING N&S"
txtcount=STRING|"1"
variable=STRING|"aaa"
Name=STRING|"Show ""{aaa}"""
msg0=STRING|"{aaa}"
ActionID=STRING|"A_XML_SAVE"
Name=STRING|"XML Save to C:\Temp\111.xml"
filename=STRING|"C:\Temp\111.xml"
ifexists=STRING|"1"
xml00000000=STRING|"{aaa}"
xmlcount=STRING|"1"
