Backup your tasks
Backup your tasks
To backup your tasks use this task example, please:
[DEMO] Backup your tasks (daily backup).tsk
This task make the incremental backup of your tasks into backup folder.
It crates separate folder for each day (the name based on date).
Of course you can change Backup folder and amount of the days as you wish. Look at the steps #1 and #3
The same task now included into installation package of RoboTask.
Also you can find more examples here: http://robotask.com/samples/
Drhishint
Re: Backup your tasks
Post by Drhishint »
Thanks for this tutorial....t's very important and useful for me =)
rgonzalez
Post by rgonzalez »
Hi Oleg, where are the settings of the tasks saved? I would like to backup all of my tasks but also if the task is enabled or disabled. Thank you.
RoboTask saves all task parameters (for example Enabled/Disabled option) in the task file.
In other words the task file contains complete information about the task.
rgonzalez
Post by rgonzalez »
If I export a task and then import it to another computer, the task always appears as disabled, this means some settings are not saved when exporting?
When you import the task or paste the task from clipboard RoboTask disables the task forcibly. It is necessary for safety.
A task can be started immediately if it contains any triggers. In most cases, you need to change something in the task or look at the structure of the task before turning it on.
So you have to enable imported task manually.
juanlu
Post by juanlu »
N.B.: don't forget about global variables. Global variables (user global variables) are not saved in tsk files, but in the windows registry (not ideal, but that's another story). That means, if you export and import a task that uses global vars, make sure that those global variable exist in the target instance of RoboTask.
Global variables are stored in system registry:
For application mode
HKEY_CURRENT_USER\Software\Neowise\RoboTask\User variables
For system service mode
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Neowise\RoboTask\User variables
You can export and import these settings by using registry actions
Hacienda
Post by Hacienda »
juanlu wrote:if you export and import a task that uses global vars, make sure that those global variable exist in the target instance of RoboTask.
How do I do it?
How do I do it?
Menu Options->Variables and open Global user variables tab
