Find captured window area
marcolobaido
Post by marcolobaido »
I use robotask to automatize a java based software but I can't use the smart feature "Move to an object" because robotask doesn't identify java buttons. This could be solved adding a feature that allow robotask to identify a captured area in a specificated window and moving the mouse in its geometrical center (like in winautomation) or, better, in a determined position.
Is there any hope you may add this feature in the next update? I think that this will make robotask much more powerful than it actually is. It will work using a "visual" method also for java based softwares.
Thanks
marcolobaido
Re: Find captured window area
Did I explained the suggestion clearly?
Yes, of course. This is already in our ToDo list.
