Calculate with FileTime
Hello Oleg,
My programming skills are not that good, so thatshwy I try it here!
I want to compare the FileTime of a file with the date of today. If the file has not been modified/created on current date, a variable should be written, like "False" or whatever.
If the FileTime equals the date of today, then it's good. The time in this case is not important, only the date (in fact: only the day) is important.
I was trying to fill a variable with the value of FileTime(File) and SubStr, but it didn't worked out.
Can you help me? :roll:
Re: Calculate with FileTime
You can calculate the date by format
{DateTimeToFormat({Date},yyyymmdd)}
{DateTimeToFormat({ftime},yyyymmdd)}
You will get the string as this 20170207
Of course you can compare it with another similar string.
Look at my example below
CatID=INTEGER|1075658632
ExternalName=STRING|"Task175"
ID=INTEGER|1604848021
Name=STRING|"Compare File Date"
Name=STRING|"Set variable ""TODAY"" with value ""{DateTimeToFormat({Date},yyyymmdd)}"""
varname=STRING|"TODAY"
varvalue=STRING|"{DateTimeToFormat({Date},yyyymmdd)}"
Name=STRING|"Show ""{Text}"""
msg0=STRING|"{Text}"
Name=STRING|"Set variable ""TEXT"" with value """""
varname=STRING|"TEXT"
Name=STRING|"File Loop"
date1=STRING|"20170207"
date2=STRING|"20170207"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"D:\incoming\*.*"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"1"
timevar=STRING|"FTIME"
Name=STRING|"Set variable ""FDATE"" with value ""{DateTimeToFormat({ftime},yyyymmdd)}"""
varname=STRING|"FDATE"
varvalue=STRING|"{DateTimeToFormat({ftime},yyyymmdd)}"
value1=STRING|"{fdate}"
value2=STRING|"{today}"
Name=STRING|"Set variable ""TEXT"" with value ""{Text}{filename}; TRUE{eol}"""
varvalue=STRING|"{Text}{filename}; TRUE{eol}"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Set variable ""TEXT"" with value ""{Text}{filename}; False{EOL}"""
varvalue=STRING|"{Text}{filename}; False{EOL}"
As usual it works straight away. Thanks!
