Problem with SFTP
dj.funny
Problem with SFTP
Post by dj.funny »
I'll have a problem with SFTP,
When I download /out/factuuradressen/25112016120320_producten.log
There is no problem!!
But because I don't know the filename I'll do it with a loop.
I've used the following formats on the item "Remote Folder and File Mask (e.g. download/*.zip):
/out/factuuradressen/*.log
/out/factuuradressen/*.*
But never there is a file found??? So he goes direct to the "End Loop" :(
Re: Problem with SFTP
Hm-m...
I tested this, it works
This example retrieves filenames test/*.txt
CatID=INTEGER|799993286
ExternalName=STRING|"Task161"
ID=INTEGER|2025316178
Name=STRING|"Test sFTP Loop"
ActionID=STRING|"A_SFTP_LOGON"
Name=STRING|"SFTP Open (username@192.168.44.129)"
host=STRING|"192.168.44.129"
password=STRING|"8300183858849008361683093"
passwordmode=STRING|"0"
port=STRING|"22"
username=STRING|"username"
ActionID=STRING|"A_SFTP_DIR"
Name=STRING|"SFTP File loop"
date1=STRING|"18991230"
date2=STRING|"18991230"
DuringMinutes=STRING|"1"
filenameonly=STRING|"0"
folder=STRING|"test/*.txt"
kind=STRING|"0"
sizesave=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subfolders=STRING|"1"
timesave=STRING|"0"
varname=STRING|"FILE"
message=STRING|"{file}"
