How to check for oldest folder
PowersL
Post by PowersL »
Newbie here.
I need to delete the oldest folder on a removeable hard disk.  How do I check for this?
Many Thanks
You can find files which older than some time by using file loop or "Search for files" action. You can't find oldest (newest) folder directly. I wrote it into our ToDo list. But I can write a BASIC script to find oldest folder in specified path if needed.
PowersL
Post by PowersL »
Oleg,
Is there any documentation on the basic script language?  Any examples.  I'm pretty good with basic programming, VB etc.  Unless you have something already written.
Many thanks
Basic have complete help about language and Script editor inteface.
In script editor press F1.
A few examples with using BASIC scripts you will find in the root of tasks tree after installation of BASIC-plugin.
