dj.funny
Post
by dj.funny »
Dear readers,
Excuse formy English but that's not my cup of tea
I have the following question:
With the function POP3 Mail loop I'll extract the emailadress of the sender out of an email. But I only need the email adress not all the other stuff:
Maybe an example makes it easier for all you!
Sometimes I'll get:
dirk@vroxxx.nl and that's what I want, but other times I'll get:
"Dirk Vroxxx | Company Yyyy" <dv@vierxxx.com> But in this case I only need
dv@vierxxx.com
Is there somebody with the answer??
- Site Admin
Post
by Oleg »
Use
AddressOnly system variable (function)
It is in the list of variables: menu
Options->Variables
Look in the
EMail group
Also see my example below.
Save the text of the task to a file and use menu
Task->Import to import the task into RoboTask.
ExternalName=STRING|"Task110"
ID=INTEGER|1341975447
Name=STRING|"Email address only demo"
Name=STRING|"Set variable ""EMAIL1"" with value ""dirk@vroxxx.nl"""
varname=STRING|"EMAIL1"
varvalue=STRING|"dirk@vroxxx.nl"
Name=STRING|"Set variable ""EMAIL2"" with value """"Dirk Vroxxx | Company Yyyy"" <dv@vierxxx.com>"""
varname=STRING|"EMAIL2"
varvalue=STRING|"""Dirk Vroxxx | Company Yyyy"" <dv@vierxxx.com>"
Name=STRING|"Show ""{AddressOnly({email1})}"""
msg0=STRING|"{AddressOnly({email1})}"
msg1=STRING|"{AddressOnly({email2})}"
msgcount=STRING|"2"
dj.funny
Post
by dj.funny »
Sometimes live is so easy
I allready solved it (with STR replace + STR pos + STR delete), but this is so much better!!
Now I use your solution!! Many thanks!!
