Wait for new file from here - If excist, run script further?
snowseals
Post by snowseals »
How do I create a script that Waits for a new file to be saved in a specific folder?
And when it does excist, then proceed with the script?
Note:
I'm trying to let the script run further auto-pilot, after I saved a document.
This document always ends up in same folder, but with different names.
Extension is .docx
After it's been saved (a new file therefor), the script should proceed.
Re: Wait for new file from here - If excist, run script furt
Use File Monitor trigger
It can monitor new files by mask and start the task
snowseals
Post by snowseals »
I was looking under Actions instead of Triggering Events, Thanks!
Works ;)
Look at this example below.
It waits for existence of the file for 1 minute
ExternalName=STRING|"Task105"
ID=INTEGER|-1457413517
Name=STRING|"Wait for file"
Name=STRING|"Set variable ""FILENAME"" with value ""c:\incoming\test.txt"""
varname=STRING|"FILENAME"
varvalue=STRING|"c:\incoming\test.txt"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""Timeout error"""
icon=STRING|"3"
msg0=STRING|"Timeout error"
msg1=STRING|"File {FileName} doesn't exist!"
msgcount=STRING|"2"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"60"
value1=STRING|"{FileExists({FileName})}"
Name=STRING|"Break"
Name=STRING|"Delay 1 sec"
delay=STRING|"1"
dimension=STRING|"1"
Name=STRING|"Show ""File {FileName} exists!"""
msg0=STRING|"File {FileName} exists!"
