Robotask 6.7 doesnt click in Word's Ribbon-bar anymore?
snowseals
Post by snowseals »
I asked u a while ago, how to click in the Ribbon-bar of Word, with Robotask's Macro-recorder, here: http://robotask.com/forum/viewtopic.php ... 5742#p5742
You came up with 2 solutions, and I preferered the 2nd one.
But it's not working anymore since Robotask 6.7...?
Instead, it does a PGUP or ARROW UP, i dont know, the page goes up somehow.
Check out for yourself, a test below:
CatID=INTEGER|0
ExternalName=STRING|"Task17"
ID=INTEGER|53882418
Name=STRING|"Test met klikken in Word ribbon-bar"
Name=STRING|"//Begin of MacroRecoder block"
comment=STRING|"Begin of MacroRecoder block"
Name=STRING|"Delay"
delay=STRING|"11"
ActionID=STRING|"A_MOUSE_MOVETO"
Name=STRING|"Move To Object"
bottom=STRING|"305"
controlclass=STRING|"NetUIHWND"
ctrlclassexact=STRING|"0"
ctrltextexact=STRING|"1"
left=STRING|"0"
right=STRING|"216"
top=STRING|"0"
winclassexact=STRING|"0"
windowclass=STRING|"Net UI Tool Window"
wintextexact=STRING|"0"
x=STRING|"32"
y=STRING|"44"
Name=STRING|"Click button"
[Actions\Action12\Params]
action=STRING|"0"
button=STRING|"0"
Name=STRING|"//End of MacroRecoder block"
[Actions\Action13\Params]
comment=STRING|"End of MacroRecoder block"
bottom=STRING|"147"
left=STRING|"0"
right=STRING|"1920"
top=STRING|"0"
windowclass=STRING|"OpusApp"
windowtext=STRING|"- Microsoft Word"
x=STRING|"851"
y=STRING|"4"
action=STRING|"0"
button=STRING|"0"
Name=STRING|"Delay"
delay=STRING|"15"
bottom=STRING|"147"
left=STRING|"0"
right=STRING|"1920"
top=STRING|"0"
x=STRING|"209"
y=STRING|"37"
action=STRING|"0"
button=STRING|"0"
Name=STRING|"Delay"
delay=STRING|"10"
bottom=STRING|"147"
left=STRING|"0"
right=STRING|"1920"
top=STRING|"0"
x=STRING|"181"
y=STRING|"95"
action=STRING|"0"
button=STRING|"0"
Re: Robotask 6.7 doesnt click in Word's Ribbon-bar anymore?
Hm-m...
I have tested your task on my computer - it works
The task sets the layout of the page to portrait orientation.
snowseals
Post by snowseals »
I found the bug(?)
When the Panel is open of Word, it does this strange behavior.
The panel is that overview on the left, See attachment for the overview of my template.
You can open that Panel, by click in the left bottom on Pages, see attachment.
It doesnt happen if there is no content in that Overview, like the heads that are filled in.
I've attached a test document with such Content-list, so you can test it yourself.
EDIT:
I tested the Content-test.docx out myself on different computer with same Office version and 64-bit,
and there it works flawlessly.
I'll do some more investigation...
Content-test.zip
(10.51 KiB) Downloaded 1974 times
snowseals
Post by snowseals »
So I tested it out on different computer, where it worked.
I recorded it again on that pc, and then it failed (along with Content-test.docx)
The one that works flawless:
CatID=INTEGER|0
ID=INTEGER|53882418
Name=STRING|"Test met klikken in Word ribbon-bar (imported)"
Name=STRING|"Delay"
delay=STRING|"11"
bottom=STRING|"305"
left=STRING|"0"
right=STRING|"216"
top=STRING|"0"
x=STRING|"32"
y=STRING|"44"
action=STRING|"0"
button=STRING|"0"
bottom=STRING|"147"
left=STRING|"0"
right=STRING|"1920"
top=STRING|"0"
x=STRING|"851"
y=STRING|"4"
action=STRING|"0"
button=STRING|"0"
Name=STRING|"Delay"
delay=STRING|"15"
bottom=STRING|"147"
left=STRING|"0"
right=STRING|"1920"
top=STRING|"0"
x=STRING|"209"
y=STRING|"37"
action=STRING|"0"
button=STRING|"0"
Name=STRING|"Delay"
delay=STRING|"10"
bottom=STRING|"147"
left=STRING|"0"
right=STRING|"1920"
top=STRING|"0"
x=STRING|"181"
y=STRING|"95"
action=STRING|"0"
button=STRING|"0"
The one that fails (recorded on the working pc):
CatID=INTEGER|0
ID=INTEGER|53882418
Name=STRING|"Test met klikken in Word ribbon-bar fails"
Name=STRING|"Delay"
delay=STRING|"13"
bottom=STRING|"175"
left=STRING|"0"
right=STRING|"1280"
top=STRING|"0"
x=STRING|"172"
y=STRING|"101"
action=STRING|"0"
button=STRING|"0"
bottom=STRING|"175"
left=STRING|"0"
right=STRING|"1280"
top=STRING|"0"
x=STRING|"183"
y=STRING|"47"
action=STRING|"0"
button=STRING|"0"
Name=STRING|"Delay"
delay=STRING|"18"
bottom=STRING|"175"
left=STRING|"0"
right=STRING|"1280"
top=STRING|"0"
x=STRING|"427"
y=STRING|"4"
action=STRING|"0"
button=STRING|"0"
Name=STRING|"Delay"
delay=STRING|"7"
bottom=STRING|"175"
left=STRING|"0"
right=STRING|"1280"
top=STRING|"0"
x=STRING|"198"
y=STRING|"44"
action=STRING|"0"
button=STRING|"0"
snowseals
Post by snowseals »
The one that failed, works on different pc with 1440x900 resolution (where its never been recorded).
The one that works, fails on that PC.
snowseals
Post by snowseals »
Found it!
Somehow I have to set the Control Positions to Zero, and then it works on any PC->read resolution.
Including the one where it's been recorded (otherwise it fails).
See attachment.
snowseals
Post by snowseals »
I tried it out with older version of Robotask, and indeed, then it just works without problems.
Then there is no need to set those Control Positions to Zero.
What could be the issue here?
Is Robotask 6.7 more strict?
I mean, my main issue is, now I have to change Actions based on older version, to make it work with v6.7.
What version?
The action was not being changed very long time. But we'll check this again.
Also your example works fine on my computers and the latest version of RoboTask
snowseals
Post by snowseals »
Let's call those scripts v1 and v2; those are the ones I pasted in one of the previous replies, above.
Version 6.4 works with both scripts.
See video: https://youtu.be/wuV8J9RBG2U
Version 6.7 works with v1, but fails with v2.
See video: https://youtu.be/nYwA9vcnzUI
NOTE: This was recorded at a laptop with 1280x800 resolution.
The one that failed, was actually Macro-recorded on that same machine (which makes it even weirder).
snowseals
Post by snowseals »
When I play those 2 scripts on a machine with 1920x1080 resolution, they both work on Robotask 6.7.
But when I Macro-record this same handling/action on that machine, it fails.
Hereby, the script that I Macro-recorded on 1920x1080 machine:
CatID=INTEGER|0
ExternalName=STRING|"Task30"
ID=INTEGER|2014734799
Name=STRING|"Test met klikken in Word ribbon-bar 1920x1080"
bottom=STRING|"147"
left=STRING|"0"
right=STRING|"1920"
top=STRING|"0"
x=STRING|"292"
y=STRING|"4"
action=STRING|"0"
button=STRING|"0"
Name=STRING|"Delay"
delay=STRING|"5"
bottom=STRING|"147"
left=STRING|"0"
right=STRING|"1920"
top=STRING|"0"
x=STRING|"224"
y=STRING|"36"
action=STRING|"0"
button=STRING|"0"
Name=STRING|"Delay"
delay=STRING|"7"
bottom=STRING|"147"
left=STRING|"0"
right=STRING|"1920"
top=STRING|"0"
x=STRING|"220"
y=STRING|"86"
action=STRING|"0"
button=STRING|"0"
