Selecting part Action List to disable not working
snowseals
Post by snowseals »
When I try to Disable a part of an Action List inside a Task, by selecting them, holding Shift, I'd like to hit Spacebar so all the ''Checks'' in front would be removed.
But that's not working. It will only remove 1 check; the check of the one Action, clicked last of that selection.
Neither right-clicking the section gives this option.
This way I can, for the time-being, Disable parts in my Task, to know what is going on for those Actions that arent disabled (without deleting the rest of the Action List).
Could u make this available in an update Oleg?
Re: Selecting part Action List to disable not working
Thank you for the information.
Already corrected. It will be in next release.
