Java software buttons
marcolobaido
Post by marcolobaido »
I use robotask to automate a software based on java.
When I use "Move to an Object" action, robotask remember only:
- Window caption
- Window class
but NOT control text.
Can robotask individuate other software's buttons?
If not, can you add a new action that saves the button screenshot and then clicks on it?
Thank you
Re: Java software buttons
Java applications use its own control elements of a window.
I'm afraid that you have to use mouse coordinates in the window only in this case.
marcolobaido
It would be usefull adding an action that identify every button of every software capturing its image...this will make robotask a very powerful tool. Can you add it in your "to do" list, please?
