Parsing text
kravtsov
Parsing text
Post by kravtsov »
How can i extract few variables from text?
I want to receive these variables as a result of parsing:
{surname}=Иванов
{firstname}=Иван
{middlename}=Иванович
{birthdate}=01.01.1990
{birthplace}=Нижний Новгород
{passport }=1
{passser}=1122
{passnum}=112233
{passdate}=03.02.2011
{passplace}=Нижний Новгород
{passorg}=ОУФМС России в Нижегородской области в Канавинском районе г. Нижнего Новгорода
{regRegion}=52
{regcity}=Нижний Новгород
{regstreet}=пр-т Ленина
{reghouse}=21
{regflat}=12
{email}=test@test.com
{phone}=89161112233
Hey there,
Someone just submitted your form on testformspree.com/. Here's what they had to say:
surname
Иванов
firstname
Иван
middlename
Иванович
birthdate
01.01.1990
birthplace
Нижний Новгород
passport
1
passser
1122
passnum
112233
passdate
03.02.2011
passplace
Нижний Новгород
passorg
regRegion
52
regcity
Нижний Новгород
regstreet
пр-т Ленина
reghouse
21
regflat
12
email
test@test.com
phone
89161112233
message
This form was submitted at 10:57 AM UTC - 10 November 2016.
You are receiving this because you confirmed this email address on Formspree. If you don't remember doing that, or no longer wish to receive these emails, please remove the form on testformspree.com/ or send an email to team@formspree.io.
Re: Parsing text
For example see the task below
One of algorithms.
You can the text from text file directly in the step #4 (Text loop)
CatID=INTEGER|1040932817
ExternalName=STRING|"Task155"
ID=INTEGER|1352064740
Name=STRING|"parse text"
Action14=FOLDER
Action15=FOLDER
Name=STRING|"Create local variable ""TEXT"" with value ""Hey there,{EOL}Someone just submitted your form on..."""
varname=STRING|"TEXT"
varvalue=STRING|"Hey there,{EOL}Someone just submitted your form on testformspree.com/. Here's what they had to say:{EOL}surname    {EOL}{EOL}Иванов{EOL}{EOL}firstname    {EOL}{EOL}Иван   {EOL}{EOL}middlename    {EOL}{EOL}Иванович{EOL}{EOL}birthdate    {EOL}{EOL}01.01.1990{EOL}{EOL}birthplace    {EOL}{EOL}Нижний Новгород{EOL}{EOL}passport    {EOL}{EOL}1{EOL}{EOL}passser    {EOL}{EOL}1122{EOL}{EOL}passnum    {EOL}{EOL}112233{EOL}{EOL}passdate    {EOL}{EOL}03.02.2011{EOL}{EOL}passplace    {EOL}{EOL}Нижний Новгород{EOL}{EOL}passorg    {EOL}{EOL}ОУФМС России в Нижегородской области в Канавинском районе г. Нижнего Новгорода{EOL}{EOL}regRegion    {EOL}{EOL}52{EOL}{EOL}regcity    {EOL}{EOL}Нижний Новгород{EOL}{EOL}regstreet    {EOL}{EOL}пр-т Ленина{EOL}{EOL}reghouse    {EOL}{EOL}21{EOL}{EOL}regflat    {EOL}{EOL}12{EOL}{EOL}email    {EOL}{EOL}test@test.com{EOL}{EOL}phone    {EOL}{EOL}89161112233{EOL}{EOL}message    {EOL}{EOL}{EOL}{EOL}This form was submitted at 10:57 AM UTC - 10 November 2016.{EOL}You are receiving this because you confirmed this email address on Formspree. If you don't remember doing that, or no longer wish to receive these emails, please remove the form on testformspree.com/ or send an email to team@formspree.io."
type=STRING|"1"
value1=STRING|"{num}"
value2=STRING|"2"
Name=STRING|"Set variable ""{VARNAME}"" with value ""{Line}"""
varname=STRING|"{VARNAME}"
varvalue=STRING|"{Line}"
[Actions\Action13\Params]
incement=STRING|"1"
vaiable=STRING|"num"
[Actions\Action14]
[Actions\Action15]
Name=STRING|"Show ""surname = {surname}"""
[Actions\Action15\Params]
msg0=STRING|"surname = {surname}"
msg1=STRING|"firstname = {firstname} "
msg10=STRING|"passorg = {passorg}"
msg11=STRING|"regRegion = {regRegion}"
msg12=STRING|"regcity = {regcity}"
msg13=STRING|"regstreet = {regstreet}"
msg14=STRING|"reghouse = {reghouse}"
msg15=STRING|"regflat = {regflat}"
msg16=STRING|"email = {email}"
msg17=STRING|"phone = {phone}"
msg2=STRING|"middlename = {middlename}"
msg3=STRING|"birthdate = {birthdate}"
msg4=STRING|"birthplace = {birthplace}"
msg5=STRING|"passport = {passport}"
msg6=STRING|"passser = {passser}"
msg7=STRING|"passnum = {passnum}"
msg8=STRING|"passdate = {passdate}"
msg9=STRING|"passplace = {passplace}"
msgcount=STRING|"18"
Name=STRING|"Create local variable ""KEYWORDS"" with value ""surname,firstname,middlename,birthdate,birthplace,..."""
varname=STRING|"KEYWORDS"
varvalue=STRING|"surname,firstname,middlename,birthdate,birthplace,passport,passser,passnum,passdate,passplace,passorg,regRegion,regcity,regstreet,reghouse,regflat,email,phone"
Name=STRING|"Set variable ""NUM"" with value ""5"""
varname=STRING|"NUM"
varvalue=STRING|"5"
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
line0=STRING|"{Text}"
sourcetext=STRING|"1"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{Line}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"Line"
operator=STRING|"6"
value1=STRING|"{Line}"
value2=STRING|"{KeyWords}"
Name=STRING|"Set variable ""VARNAME"" with value ""{Line}"""
varname=STRING|"VARNAME"
Name=STRING|"Set variable ""NUM"" with value ""0"""
varvalue=STRING|"0"
kravtsov
Re: Parsing text
Post by kravtsov »
WOW!!! Robotask is the magic program! Can you explain to me and others how this script works?
Re: Parsing text
The task reads each second line after keyword.
The each keyword is the name of variable
Find the keyword and reset the counter to 0 (variable num)
Line 0 - keyword. Also the name of variable
Line 1 - empty (skipped)
Line 2 - the value of variable
Other lines are skipped
The task contains only 15 steps. It is not too complex.
