Get unread Email
kravtsov
Get unread Email
Post by kravtsov »
Hi!
How can I download unread messages from using POP3 or IMAP and mark them as "read"?
It is easy to download all messages using LOOP. But I don't understand how can I get the number of unread messages.
Re: Get unread Email
IMAP Mail loop action allows to save the message flags too
To save flags (attributes) of the current message, switch on this checkbox and specify the variable name. Flags of the message will be saved as string. Every letter corresponds to existence of a flag of the message.
  • A - Answered
    F - Flagged
    D - Deleted
    S - Seen
    T - Draft
    R - Recent
For example,
AS - means that the message is answered and seen.
R – recent message.
There is IMAP Get Message Flags to save message flags within the loop into varable
Also look at my example below.
CatID=INTEGER|1040932817
ExternalName=STRING|"Task149"
ID=INTEGER|-122231251
Name=STRING|"download unread messages (example)"
ActionID=STRING|"A_IMAP_OPEN"
Name=STRING|"IMAP Open"
folder=STRING|"INBOX"
host=STRING|"imap.myserver.com"
password=STRING|"4438845245462874500344480"
passwordmode=STRING|"0"
port=STRING|"993"
SSL=STRING|"1"
user=STRING|"username"
ActionID=STRING|"A_IMAP_LOOP"
Name=STRING|"IMAP Mail loop"
flags=STRING|"Flags"
number=STRING|"num"
usecc=STRING|"0"
usedate=STRING|"0"
useflags=STRING|"1"
usefrom=STRING|"0"
usesize=STRING|"0"
usesubj=STRING|"0"
useto=STRING|"0"
operator=STRING|"9"
value1=STRING|"S"
value2=STRING|"{Flags}"
Name=STRING|"//process unread messages here"
comment=STRING|"process unread messages here"
Name=STRING|"//you can dowload it too"
comment=STRING|"you can dowload it too"
Name=STRING|"//and set ""read"" flag"
comment=STRING|"and set ""read"" flag"
ActionID=STRING|"A_IMAP_SETFLAGS"
Name=STRING|"IMAP Set Message Flags"
answered=STRING|"2"
deleted=STRING|"2"
draft=STRING|"2"
flagged=STRING|"2"
msgnum=STRING|"{num}"
recent=STRING|"2"
seen=STRING|"1"
kravtsov
Post by kravtsov »
Thanks!
