Monitor File Size
smiffer
Monitor File Size
Post by smiffer »
I'm new to RoboTask and need a little help. I'd like to monitor a folder and if a certain file size is greater than 100KB FTP the file. I found the File Monitor but that checks if the size has changed. I would like to monitor and if the file size is greater than 100KB then upload the file via FTP.
Re: Monitor File Size
Look at my example below.
I think the algorithm is clear.
You have to get the list from FTP and compare file size with size of local file (VB Evaluate action)
If the size is greater than FTP size on 100K upload it.
Also attach the Cyclic trigger to run this task every hour
Look at the task in the task editor and correct it for your own purposes.
CatID=INTEGER|1360203151
ExternalName=STRING|"Task39"
ID=INTEGER|1883862383
Name=STRING|"uppload files is it greater the FTP file on 100K"
Name=STRING|"Create local variable ""FTPFOLDER"" with value ""/incoming"""
varname=STRING|"FTPFOLDER"
varvalue=STRING|"/incoming"
ActionID=STRING|"A_SSLFTP_LOGOFF"
Name=STRING|"SSL FTP Log Off"
Name=STRING|"Create local variable ""LOCALFOLDER"" with value ""c:\toupload"""
varname=STRING|"LOCALFOLDER"
varvalue=STRING|"c:\toupload"
ActionID=STRING|"A_SSLFTP_LOGON"
Name=STRING|"SSL FTP Log On"
anonymous=STRING|"1"
host=STRING|"ftp.myserver.com"
passive=STRING|"1"
port=STRING|"21"
proxypassword=STRING|"2565724937259662673825194"
proxytype=STRING|"3"
tlsmode=STRING|"0"
useproxy=STRING|"0"
username=STRING|"anonymous"
usessl2=STRING|"0"
usessl3=STRING|"0"
usestls=STRING|"1"
ActionID=STRING|"A_SFTP_DIR"
Name=STRING|"SFTP File loop"
date1=STRING|"18991230"
date2=STRING|"18991230"
DuringMinutes=STRING|"1"
filenameonly=STRING|"1"
folder=STRING|"{ftpfolder}/*.*"
kind=STRING|"0"
sizesave=STRING|"1"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subfolders=STRING|"0"
timesave=STRING|"0"
varname=STRING|"FTPFILE"
varsize=STRING|"FTPSIZE"
value1=STRING|"{FileExists({LocalFolder}\{FTPFile})}"
Name=STRING|"VB Evaluate"
expression=STRING|"{FileSize({LocalFolder}\{FTPFile})} - {FTPSize}"
linecount=STRING|"0"
loadfromfile=STRING|"1"
variable=STRING|"delta"
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{Delta}"
value2=STRING|"100000"
ActionID=STRING|"A_SSLFTP_UPLOAD"
Name=STRING|"SSL FTP Upload"
file=STRING|"{LocalFolder}\{FTPFile}"
folder=STRING|"{FTPFolder}"
ifexists=STRING|"0"
UniqueID=INTEGER|-1560453937
interval=STRING|"3600"
notsatrtatactivation=STRING|"1"
