Zip / Pack Empty Folders
RomaRS
Post by RomaRS »
Hello all,
i am struggling to create a task that can zip a Folder with a 1 zip file and inside the folder exist many empty folders and some of them have also files.
i tried everything , can someone help with this one
Folder1 (this one should be zipped with Folder1.zip)
+++import1(Folder)
+++Import2(Folder)
+++import500(Folder)
+++++++FileTest.txt (File)
+++++++FileTest2.txt (File)
+++import2000(Folder)
what i did
i loop by folder then
change folder path
then pack
but in result i get inside zip file only the folder that have a file inside
and i need inside the zip all the list with empty folders
Thank you
Re: Zip / Pack Empty Folders
Unfortunately Pack Files action ignores empty folders.
But you can use free command line utility to pack folders as you wish.
For example 7-zip. It supports ZIP format too.
To pack the folder with files and empty folders use the command:
  • 7z.exe a -tzip <ZIP_name> <Folder_Name>
RomaRS
Post by RomaRS »
Perfect Oleg,
it worked using command line
thx
