Substract MonthName
Substract MonthName
Hello everyone,
Due to lack of VB skills, most likely this stupid question ;)
In Robotask, a report is being generated for the previous month. In short: {MonthNo} - 1 will do.
The report should be mailed, but instead of "Report of 10", ofcourse the best way is "Report of Oktober". (The report is generated in November). So: variable {MonthName} should be used.
Ofcourse, I cannot do {MonthName-1}. How can I make sure the name of the previous is being used?
Re: Substract MonthName
RoboTask contains the system variable IncMonths
For previous month use: {IncMonths(-1)}
Basic script language has the function MonthName (see here for details)
So, to calculate the previous month name use the expression MonthName({IncMonths(-1)}) in the VB Evaluate action
Also look at my example below
ExternalName=STRING|"Task87"
ID=INTEGER|1568618943
Name=STRING|"previous month name"
Name=STRING|"VB Evaluate"
expression=STRING|"MonthName({IncMonths(-1)})"
line00000000=STRING|"'"
loadfromfile=STRING|"1"
variable=STRING|"nam"
Name=STRING|"Show ""Current month: {MonthName}"""
msg0=STRING|"Current month: {MonthName}"
msg1=STRING|"Previouse month: {nam}"
msgcount=STRING|"2"
Works perfectly. Many thanks!
