New Trigger problem
WellWisher
New Trigger problem
Post by WellWisher »
Hello, in the last update you have added a new trigger Pixels Monitor, to be honest for a long time waiting for something like that. But it does not work well, and sometimes does not work. Even if you "ENABLE=FALSE " the task she still continues to work at all that strange. And if everything is correct by color it does not always work, and still would like to ask you to add a function Region Pixel Monitor, I think you know what should be in it have been realized. Thanks you.
Re: New Trigger problem
Thank you for the report.
We'll investigate the problem and will correct it ASAP.
Already fixed.
Download and install fresh copy please: http://robotask.com/downloads/RobotaskSetup.exe
...would like to ask you to add a function Region Pixel Monitor...
Small region is not a pixel. It can contain pixels with different colors.
But single pixel has one color only.
WellWisher
I found another bug, then you click Change Windows Class
and choose for example "Progman"
Change Window Caption Image
Fixed.
Download fresh copy, please: http://robotask.com/downloads/RobotaskSetup.exe
