Enable / disable action with selecting
Currently, you only have the option to select or unselect all actions in a task for enabling or disabling them.
It would be great that if you select multiple actions, you can tick them on or off and leave the rest the way it is.
Now, when I select 20 actions and press for example the space bar, only the action with the focus is enabled / disabled instead of the complete selection.
Re: Enable / disable action with selecting
Ok
