Basic Script issues
tplehman
Basic Script issues
Post by tplehman »
Can you enlighten me on why I am getting the following error:0
Method or property not found. Line 12 Col 14 ""
as a result of running the following Basic Script as a Task with nothing else in it:
Sub Main
Dim FileName As String
Dim TempString As String
FileName = "C:\test.tsk"
Open FileName For Input As #1
 While Not EOF(1)
     Line Input #1, S$
     If InStr(S$,"Name=STRING|") Then
   TempString = Mid(S$,14,)
   If Mid(TempString,8,) = "no_auto_" Then
   Else
    App.SetUserVariable("TASK_NAME_FROM_ FILE",TempString)
    MsgBox "Set TASK_NAME_FROM_FILE = " & TempString
   End If
     End If
    Wend
Close #1
End Sub
The script runs fine in the Sax Basic IDE, and it doesn't seem to matter whether the script is internal or external.
Thanks,
Basic Script issues
Use the RoboTaskApp object instead of App
Write it so:
RoboTaskApp.SetUserVariable("TASK_NAME_FROM_ FILE",TempString)
