How to increase the minutes of some time?
There's no TimeIncMinutes()...
{TimeIncMinutes({Time})}
Re: {TimeIncMinutes({Time})}
Look at my example below.
You can use VB script to create any function.
The function is very simple:
CatID=INTEGER|341701671
ExternalName=STRING|"Task256"
ID=INTEGER|-1285742625
Name=STRING|"TimeIncMinutes"
Name=STRING|"Set variable ""TM"" with value ""{Time}"""
varname=STRING|"TM"
varvalue=STRING|"{Time}"
Name=STRING|"VB Evaluate"
expression=STRING|"TimeIncMinutes(""{tm}"", 15)"
line00000000=STRING|"function TimeIncMinutes(tm, add)"
line00000001=STRING|" TimeIncMinutes = DateAdd(""n"", CInt(add), CDate(tm))"
line00000002=STRING|"end function"
line00000004=STRING|"'logmessage(TimeIncMinutes(Now, ""12""))"
linecount=STRING|"5"
loadfromfile=STRING|"1"
variable=STRING|"aaa"
Name=STRING|"Show ""Current time: {tm}"""
msg0=STRING|"Current time: {tm}"
msg1=STRING|"Added time: {aaa}"
msgcount=STRING|"2"
TimeIncMinutes = DateAdd("n", CInt(add), CDate(tm))
end functionOleg Yershov
Read more about DateAdd function here: https://msdn.microsoft.com/en-us/library/cb7z8yf9(v=vs.84).aspx
