Open cd drive as trigger
Dimsok
Post by Dimsok »
I want to start program after inserting cd or dvd in drive. Did try file monitor as trigger or variables like {VolumeLabel(j:)} to start total commander with /S /O /L /T J:/. The same with E: for the first cd drive. Total commander open disc in new tab after inserting. But when i put out disc from drive trigger works again and tries to open empty drive. Is it possible to do some condition which will make action only after inserting disc in dvd drive, but not after putting it out?
Re: Open cd drive as trigger
RoboTask contains such trigger.
Look at the On Device Changed trigger
It is in "System Events" group
This trigger fired when you insert CD/DVD into optical drive or insert external storage into USB port (flash-drive or external HDD)
SIS
Post by SIS »
what's the trigger when i connect a USB Drive?
i want that when i connect a certain USB drive it should run a task to copy a folder.
Thanks
Trigger the same: On Device Changed
You can check disk label. For example your backup drive should have the label MYBACKUP
Look at the example below
CatID=INTEGER|1657389313
ExternalName=STRING|"Task219"
ID=INTEGER|561213642
Name=STRING|"Check USB drive"
Enabled=INTEGER|0
Name=STRING|"Show ""{dsk}"""
msg0=STRING|"{dsk}"
msg1=STRING|"{VolumeLabel({dsk}:\)}"
msgcount=STRING|"2"
value1=STRING|"{VolumeLabel({dsk}:\)}"
value2=STRING|"mybackup"
Name=STRING|"Show ""Disk {dsk}: inserved"""
msg0=STRING|"Disk {dsk}: inserved"
msg1=STRING|"It is my backup drive."
msg2=STRING|"You can put here synchronization of your working folders"
msgcount=STRING|"3"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
icon=STRING|"0"
msg1=STRING|"It is NOT my backup drive."
msgcount=STRING|"2"
EventID=STRING|"E_SYSEVENTS_DEVICECHANGE"
UnigueID=INTEGER|16445697
assign=STRING|"0"
changekind=STRING|"1"
devicekind=STRING|"1"
parameter=STRING|"dsk"
useparameter=STRING|"1"
