Search for last character of the same kind in a string
pancakegh
Post by pancakegh »
Is there a way to find the position of the last character of the same kind in a string?
for example:
I want to rename my files to "387.20.1082.jpg"
the files are all named: "nike-kaishi-grijze-lage-kinder-sneakers-24139-387.20.1082.jpg"
The text part is always different and the number of " - " symbols are always different too, depending on the names.
I know I can search for the " - " substring, but how do I find the position of the last " - " character so I can delete the piece of string up until that position? So the "387.20.1082.jpg" part remains as a result?
Re: Search for last character of the same kind in a string
See below two examples
Example 1 uses Strings actions
ExternalName=STRING|"Task177"
ID=INTEGER|-1482684932
Name=STRING|"rename file"
Name=STRING|"Create local variable ""SOURNAME"" with value ""nike-kaishi-grijze-lage-kinder-sneakers-24139-387...."""
varname=STRING|"SOURNAME"
varvalue=STRING|"nike-kaishi-grijze-lage-kinder-sneakers-24139-387.20.1082.jpg"
Name=STRING|"Show ""Source:"""
msg0=STRING|"Source:"
msg1=STRING|"{SourName}"
msg3=STRING|"Result:"
msg4=STRING|"{DestName}"
msgcount=STRING|"5"
Name=STRING|"Create local variable ""DESTNAME"" with value ""{SourName}"""
varname=STRING|"DESTNAME"
varvalue=STRING|"{SourName}"
ActionID=STRING|"A_STR_POS"
Name=STRING|"STR Pos"
from=STRING|"1"
search=STRING|"-"
source=STRING|"{DestName}"
variable=STRING|"pos"
Name=STRING|"While loop"
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{pos}"
value2=STRING|"0"
Name=STRING|"Increment variable ""pos"""
incement=STRING|"1"
vaiable=STRING|"pos"
Name=STRING|"STR Extract"
amount=STRING|"255"
from=STRING|"{pos}"
variable=STRING|"DestName"
Enabled=INTEGER|0
message=STRING|"{pos}| {DestName}"
from=STRING|"1"
search=STRING|"-"
Example 2 uses regular expressions.
It is more simple but you have to be familiar with the syntax of regular expressions, of course.
ExternalName=STRING|"Task176"
ID=INTEGER|-1134236235
Name=STRING|"rename file (regex)"
Name=STRING|"Create local variable ""DESTNAME"" with value """""
Name=STRING|"RegExp Replace"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{sourname}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"(?U).+(\d+\.\d+\.\d+\.jpg)"
replacementcount=STRING|"0"
replacemode=STRING|"0"
repline00000000=STRING|"$1"
replinecount=STRING|"1"
singleline=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"destname"
msgcount=STRING|"5"
Save the text of the tasks to a files and use menu Task->Import to import the task into RoboTask.
