Number of days between two dates (dd/mm/yyyy)
marcolobaido
Post by marcolobaido »
Hi everybody,
How can I obtain the number of days between two dates: date1 - date2 = number of days (where date1>date2).
I tried to use the "VBscript" function but it's too complex for me, I should learn the programming language. :roll:
Re: Number of days between two dates (dd/mm/yyyy)
See the example below.
Only one string on VBscript
ExternalName=STRING|"Task116"
ID=INTEGER|843892749
Name=STRING|"days between"
Name=STRING|"//d2 > d1"
comment=STRING|"d2 > d1"
Name=STRING|"Set variable ""D1"" with value ""{DateTimeToFormat({DateIncDays(-20)},dd/mm/yyyy)}"""
varname=STRING|"D1"
varvalue=STRING|"{DateTimeToFormat({DateIncDays(-20)},dd/mm/yyyy)}"
Name=STRING|"Set variable ""D2"" with value ""{DateTimeToFormat({DateIncDays(7)},dd/mm/yyyy)}"""
varname=STRING|"D2"
varvalue=STRING|"{DateTimeToFormat({DateIncDays(7)},dd/mm/yyyy)}"
Name=STRING|"VB Evaluate"
expression=STRING|"DateDiff(""d"", ""{FormatToDateTime({d1},dd/mm/yyyy)}"", ""{FormatToDateTime({d2},dd/mm/yyyy)}"" )"
linecount=STRING|"0"
loadfromfile=STRING|"1"
variable=STRING|"dif"
Name=STRING|"Show ""d1 = {d1}"""
msg0=STRING|"d1 = {d1}"
msg1=STRING|"d2 = {d2}"
msg3=STRING|"dif = d2 - d1 = {dif}"
msgcount=STRING|"4"
marcolobaido
thank you very much!!! :D
