Start Application Timer
Salnikov.sv
Post by Salnikov.sv »
Hello. I need to organize a monitoring program performance. app launch will take place at the same time will start a timer that will run until the start of the application window. Result - txt file with the start time of the program window. After that, the program window is closed.
Run the application and closes the window, I realized. I can not count the time to realize and output to a file. Please help.
Re: Start Application Timer
You need two time values:
1-st value - when the program starts
2-nd value - when the program finished
see the example below:
CatID=INTEGER|1416408852
ExternalName=STRING|"Task152"
ID=INTEGER|348890740
Name=STRING|"program monitor"
Name=STRING|"Set variable ""DT1"" with value ""{dateTime}"""
varname=STRING|"DT1"
varvalue=STRING|"{dateTime}"
Name=STRING|"Run ""notepad """
ifnonzero=STRING|"0"
program=STRING|"notepad"
runas=STRING|"0"
wait=STRING|"0"
ActionID=STRING|"A_WAITFORPROCESS"
Name=STRING|"Wait for ""notepad.exe"" (Infinity)"
assign=STRING|"0"
infinity=STRING|"1"
more=STRING|"0"
process=STRING|"notepad.exe"
timeout=STRING|"60"
Name=STRING|"Set variable ""DT2"" with value ""{dateTime}"""
varname=STRING|"DT2"
Name=STRING|"VB Evaluate (dt1-dt2)"
expression=STRING|"datesubtract(""{dt1}"", ""{dt2}"")"
line00000000=STRING|"function DateSubtract(d1, d2)"
line00000001=STRING|"'d1 and d2 are strings"
line00000002=STRING|"dt1 = cdate(d1)"
line00000003=STRING|"dt2 = cdate(d2)"
line00000005=STRING|"'convert the result back to string"
line00000006=STRING|"DateSubtract = cstr(cdate(dt1-dt2))"
line00000007=STRING|"end function"
line00000009=STRING|"'aaa = DateSubtract(""12.02.2016 10:41:00"", ""00:45:10"")"
line0000000A=STRING|"'logmessage(aaa)"
linecount=STRING|"11"
loadfromfile=STRING|"1"
variable=STRING|"dt3"
Name=STRING|"Show ""date-time1  = {dt1} (Notepad starts)"""
msg0=STRING|"date-time1  = {dt1} (Notepad starts)"
msg1=STRING|"date-time2  = {dt2} (Notepad closed)"
msg2=STRING|"-----------------------"
msg3=STRING|"result = {dt3} (working time)"
msgcount=STRING|"4"
Also see more complex example.
This task monitors the NOTEPAD.exe in memory.
When you start NOTEPAD.EXE it saves beginning time into file
when you closes Notepad it calculated working time of Notepad.
This task works every 2 seconds and checks the existence of NOTEPAD in memory.
You can change the period in Cyclic trigger of this task.
ExternalName=STRING|"Task154"
ID=INTEGER|355056548
Name=STRING|"program monitor (notepad)"
ToLog=INTEGER|2
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Name=STRING|"Create local variable ""FILENAME"" with value ""{TempDir}\notepadmonitor.tmp"""
varname=STRING|"FILENAME"
varvalue=STRING|"{TempDir}\notepadmonitor.tmp"
Name=STRING|"//notepad doesn't exist"
comment=STRING|"notepad doesn't exist"
value1=STRING|"{FileExists({filename})}"
Name=STRING|"//calculate the difference"
[Actions\Action12\Params]
comment=STRING|"calculate the difference"
Name=STRING|"Set variable ""DT1"" with value ""{TextFile({filename})}"""
[Actions\Action13\Params]
varvalue=STRING|"{TextFile({filename})}"
[Actions\Action14]
Name=STRING|"Set variable ""DT2"" with value ""{DateTime}"""
[Actions\Action14\Params]
varvalue=STRING|"{DateTime}"
[Actions\Action15]
Name=STRING|"Delete File"
[Actions\Action15\Params]
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"{FileName}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
[Actions\Action16]
[Actions\Action16\Params]
[Actions\Action17]
[Actions\Action17\Params]
message=STRING|"notepad finished. Working time {dt3}"
[Actions\Action18]
[Actions\Action18\Params]
msgcount=STRING|"4"
[Actions\Action19]
value1=STRING|"{IsProcessExists(notepad.exe)}"
[Actions\Action20]
Name=STRING|"//notepad exists"
comment=STRING|"notepad exists"
operator=STRING|"1"
Name=STRING|"//save dt1"
comment=STRING|"save dt1"
message=STRING|"Save dt1 = {DateTime}"
Name=STRING|"Create text file {filename}"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"{filename}"
line0=STRING|"{dateTime}"
suppress=STRING|"1"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
UnigueID=INTEGER|16445185
interval=STRING|"2"
