Oracle query error
servio
Oracle query error
Post by servio »
Hi, I'm trialing this program and noticed that Robotask support oracle sql? my query for oracle doesn't seem to work:
spool C:\Users\VM\Desktop\QueryExport\data.csv
select DEPTNO from DEPT
1. Can someone please confirm if Robotask doesn't support Oracle SQL
2. What would be the appropriate way to write the query above?
Thank you in advanced! :)
Re: Oracle query error
The command
is not SQL command. This command is a command of Oracle SQL+
And it works only in SQL+
Look at the example below how to write the data from query into CSV file.
Of course, RoboTask can work with Oracle database.
ExternalName=STRING|"Task102"
ID=INTEGER|-528643301
Name=STRING|"data to CSV (example only)"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"C:\Users\VM\Desktop\QueryExport\data.csv"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
Name=STRING|"Dataset Loop"
commatext=STRING|"0"
connectionstring=STRING|"Provider=MSDAORA.1;User ID=user;Data Source=MyServer;Persist Security Info=False"
override=STRING|"0"
paramcount=STRING|"0"
password=STRING|"1903220363208761908018826"
sql=STRING|"""select DEPTNO from DEPT"""
timeout=STRING|"60"
var2=STRING|"ROW"
withmemo=STRING|"0"
Name=STRING|"Create text file C:\Users\VM\Desktop\QueryExport\data.csv"
encode=STRING|"0"
fileexists=STRING|"1"
filname=STRING|"C:\Users\VM\Desktop\QueryExport\data.csv"
line0=STRING|"{row}"
suppress=STRING|"0"
