Check for holiday
Check for holiday
Hai Oleg,
I have a question related to http://robotask.com/forum/viewtopic.php ... days#p1815.
We have a task which runs every day, except the weekends. But, the task should not be executed on a holiday. Ofcourse, Robotask doesn't know when a holiday "takes place", so I solved it by a simple If date = DD-MM-YYYY then stop task. Works fine, but I have to edit it every time a new holiday will come.
For sure there is an option that he checks a text or XML file for any content (= holidays for a whole year) and if the date of today is a date which is in the file mentioned, he should stop the task.
Can you please explain ?
Re: Check for holiday
See this example (see below):
You can create the list of holidays and simply stop the task if today is holiday date.
ExternalName=STRING|"Task88"
ID=INTEGER|1750422847
Name=STRING|"exclude holidays"
Name=STRING|"Create local variable ""HOLIDAYS"" with value ""01-01-2016{EOL}08-01-2016{EOL}24-08-2016"""
varname=STRING|"HOLIDAYS"
varvalue=STRING|"01-01-2016{EOL}08-01-2016{EOL}24-08-2016"
operator=STRING|"6"
value1=STRING|"{DateTimeToFormat({Date},dd-mm-yyyy)}"
value2=STRING|"{holidays}"
Name=STRING|"Show ""Today is holiday. Exiting."""
msg0=STRING|"Today is holiday. Exiting."
ActionID=STRING|"A_FLOW_EXIT"
Name=STRING|"Exit"
defh=STRING|"1"
defw=STRING|"1"
duration=STRING|"5"
height=STRING|"76"
icon=STRING|"3"
kind=STRING|"0"
message=STRING|"Place your actions here"
position=STRING|"3"
title=STRING|"Normal working"
width=STRING|"330"
Many thanks, it works perfectly.
