organize pictures
okty2k
organize pictures
Post by okty2k »
i am trying to create the followig task:
prerequisites: lots of pictures in one folder
target: move pictures based on creation date on a folder (for example - all pictures taken on 1st of march in a folder named March01)
steps:
of course, this is my idea, somebody can have a better one
1. make a list with file names (this i know)
2. for each file, get creation date (is it possible with robotask?) and move it to a folder based on day and month. if the folder does not exist, create it
can anyone help?
big thanks in advance!
Re: organize pictures
Yes, of course this is possible.
See the example below:
ExternalName=STRING|"Task87"
ID=INTEGER|777979452
Name=STRING|"organize pictures"
Name=STRING|"Create local variable ""SRCFOLDER"" with value ""C:\source"""
varname=STRING|"SRCFOLDER"
varvalue=STRING|"C:\source"
Name=STRING|"Create local variable ""DESTFOLDER"" with value ""C:\catalog"""
varname=STRING|"DESTFOLDER"
varvalue=STRING|"C:\catalog"
Name=STRING|"File Loop"
date1=STRING|"20160315"
date2=STRING|"20160315"
destvar=STRING|"C_PICTURE"
DuringMinutes=STRING|"1"
file0=STRING|"{srcFolder}\*.jpg"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"1"
timevar=STRING|"PICT_DT"
Name=STRING|"Set variable ""FLD"" with value ""{DateTimeToFormat({Pict_DT},yyyy-mm-dd)}"""
varname=STRING|"FLD"
varvalue=STRING|"{DateTimeToFormat({Pict_DT},yyyy-mm-dd)}"
Name=STRING|"Create Folder ({DestFolder}\{fld})"
newfolder=STRING|"{DestFolder}\{fld}"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"{DestFolder}\{fld}"
f_count=STRING|"1"
file0=STRING|"{c_Picture}"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"0"
rename=STRING|"0"
renamemask=STRING|"*.*.new"
subdir=STRING|"0"
system=STRING|"1"
If you want to move file (delete source file) just switch on "Move" checkbox in the step #7
okty2k
Post by okty2k »
Great, thanks!
Would it be possible to create folder for months having the name instead of the number? From what I saw in Variable description it is not, just wanted to check
Of course this is possible, use the expression
{DateTimeToFormat({Pict_DT},yyyy-mmmm-dd)}
in the step #4
See the complete list of system variables here: http://robotask.com/help/index.php?listofvariables.htm
Also you can see variables by categories in dialog: menu Options->Variables
This example is very simple. You can organize your files into any folder structure, but the algorithm will be more complex.
The format of the date "yyyy-mm-dd" is a very comfortable because you automatically sort your folders on years, months and days.
okty2k
Post by okty2k »
Thanks, but my question still remains: I want the month to be text (January) and not the number 01.
I tried defining arreys, etc, but I am not expert and is not working. :)
SORRY, JUST SAW THAT I CAN PUT -MMMM- to get the name
MMMM for month name is not present in the variable list.
