automate Zip and send mail
steveboas
Post by steveboas »
Dear all,
I have a difficulty to use this robotask, because i'm new with it. so perhaps you guys can help me out from this problem.
First thing that i want to do is pack file into zip file then send the zip file through email....i tried zip the file, n successfully but i can't send the email...i already put the sender and post to but i face a problem with smtp.. and which port that i must use.
can u guys help me.
many thx
as ur information, i use yahoo and company mail(mdaemon)
You should use same settings as in your email client. For Outlook-Express use menu "Tools | Accounts", choose desired email account and press "Properties" button. You can see host name at "Servers" tab, port - at "Advanced" tab. SMTP port is 25 by default, but it may be different for your SMTP server. You can get to know exact parameters at your internet provider.
