Leading zero with weeknumbers
Most likely an easy question for programmers, but hard for me ;)
I want to have a leading zero for weeknumbers if {WeekOfTheYear({Date})} < 10. I already tried to add a VB task and defining a local variable, called "Weeknummer". (Dutch for weeknumber).
IF {WeekOfTheYear({Date})} < 10 then Weeknummer = "0"+{WeekOfTheYear({Date})}
ELSE
Weeknummer = {WeekOfTheYear({Date})}
Can someone turn on the light on the end of the tunnel? I'm halfway! ;)
Re: Leading zero with weeknumbers
Look at the example below
ExternalName=STRING|"Task72"
ID=INTEGER|169953253
Name=STRING|"leading zero"
Name=STRING|"Set variable ""WEEKNUMMER"" with value ""{WeekOfTheYear({Date})}"""
varname=STRING|"WEEKNUMMER"
varvalue=STRING|"{WeekOfTheYear({Date})}"
operator=STRING|"5"
type=STRING|"1"
value1=STRING|"{Weeknummer}"
value2=STRING|"10"
Name=STRING|"Set variable ""WEEKNUMMER"" with value ""0{Weeknummer}"""
varvalue=STRING|"0{Weeknummer}"
Name=STRING|"Show ""Weeknummer = {Weeknummer}"""
msg0=STRING|"Weeknummer = {Weeknummer}"
Yeehaa :) Many thanks! (And when I see the task, quite simple). You just need to know.
