if / then --->> jumping to certain sections in a task
simpleuser
Post by simpleuser »
I have a question, is there a possibility in Robotask to direct the task flow to different sections of the task?
For example I make a task-section with mouse movements and mouse clicks which are always the same and these
clicks only have to be executed for example 10 times and the lead the task to another section of the task.
Do I need to make this with VB or JS or does Robotask have such commands included?
I mean commands which lets the task stream go to this or another section in condition of a variable.
Re: if / then --->> jumping to certain sections in a task
Yes, of course
Look at the actions If Then, ElseIf Then, Else
You easily can construct such algorithm
If <condition1> then
   DoSomething1
ElseIf <condition2> then
   DoSomething2
ElseIf <condition3> then
   DoSomething3
Else
   DoSomethingN
End if
