Remove everything in string past "-"
pancakegh
Post by pancakegh »
Is there a way to remove an amount of characters at the end of the string to the beginning?
say I have the variable {PROJECT} wich contains 12345-123.12.123
I only want to delete the 123.12.123 part of the string wich would be 10 characters from the back of the string.
Why delete a piece of string from the back? Because there are also files named 1234-123.12.123 so I can't go and delete from a specific point like 6 characters from the beginning.
Anyone know of a solution to delete everything past the "-" symbol?
Re: Remove everything in string past "-"
Look at my example below.
ExternalName=STRING|"Task43"
ID=INTEGER|1467404855
Name=STRING|"delete a part of string"
Name=STRING|"Set variable ""PROJECT"" with value ""12345-123.12.123"""
varname=STRING|"PROJECT"
varvalue=STRING|"12345-123.12.123"
ActionID=STRING|"A_STR_POS"
Name=STRING|"STR Pos"
from=STRING|"1"
search=STRING|"-"
source=STRING|"{project}"
variable=STRING|"pos"
type=STRING|"1"
value1=STRING|"{pos}"
value2=STRING|"0"
Name=STRING|"Show ""Symbol ""-"" is not found"""
icon=STRING|"3"
msg0=STRING|"Symbol ""-"" is not found"
ActionID=STRING|"A_FLOW_EXIT"
Name=STRING|"Exit"
ActionID=STRING|"A_STR_DELETE"
Name=STRING|"STR Delete"
amount=STRING|"999"
from=STRING|"{pos}"
variable=STRING|"project1"
Name=STRING|"Show ""old string: {project}"""
msg0=STRING|"old string: {project}"
msg1=STRING|"new string: {project1}"
msgcount=STRING|"2"
pancakegh
Post by pancakegh »
Thanks Oleg!
It works well.
Another question: Is there a way I can delete everything before {pos}?
I want to extract everything behind " - " e.g: 123.12.123 as result
Yes, of course
See the example below
ExternalName=STRING|"Task46"
ID=INTEGER|4223397
Name=STRING|"delete a part of string #2 (before POS)"
from=STRING|"1"
search=STRING|"-"
type=STRING|"1"
value2=STRING|"0"
icon=STRING|"3"
Name=STRING|"Exit"
amount=STRING|"{pos}"
from=STRING|"1"
Name=STRING|"Show both strings"
msgcount=STRING|"2"
