Outlook Express and USB
TWSI
Post by TWSI »
Hello and Good Day!
I view email from home on outlook express, is it possible to login, read my mail, parse it and save to text if it meets the requirements, or is it possible to run robotask from a USB
stick at work on outlook 10 and parse it from the usb stick.?
Thanks as always
David
Re: Outlook Express and USB
Unfortunately there are not portable versions of RoboTask.
Of course you can run RoboTask from USB drive but you will have many problems, because RoboTask uses system registry for its settings.
Also some components of RoboTask should be registered in local system.
