https://genderize.io/
Post by 5243 »
Hi Oleg,
I want to use this API within Robotask.
I want to send a name to this site.
And get back if it is a female or male.
Any Ideas
Thanks 5243
Re: https://genderize.io/
This site returns information in JSON format.
This is native format for JavaScript language. You can parse this information by using JS Script action (see step #7 in the example below)
Look at my example:
CatID=INTEGER|397884660
ExternalName=STRING|"Task27"
ID=INTEGER|1523079779
Name=STRING|"JSON parse (JS script)"
Name=STRING|"Input Box"
default=STRING|"none"
password=STRING|"0"
prompt=STRING|"Input the name"
variable=STRING|"NAME"
value1=STRING|"{name}"
value2=STRING|"none"
ActionID=STRING|"A_FLOW_EXIT"
Name=STRING|"Exit"
ActionID=STRING|"A_INET_DOWNLOAD"
Name=STRING|"Download files and save in ""{TEMPDIR}"""
action=STRING|"1"
file0=STRING|"https://api.genderize.io/?name={name}"
proxykind=STRING|"0"
saveas=STRING|"1"
saveasname=STRING|"gendersize.dat"
savedir=STRING|"{TEMPDIR}"
useproxy=STRING|"0"
Enabled=INTEGER|0
Name=STRING|"Run ""notepad.exe ""{TempDir}\gendersize.dat"""""
ifnonzero=STRING|"0"
params=STRING|"""{TempDir}\gendersize.dat"""
program=STRING|"notepad.exe"
runas=STRING|"0"
wait=STRING|"2"
ActionID=STRING|"A_SCRIPT_JSSCRIPT"
Name=STRING|"JS script"
expandvars=STRING|"0"
line00000000=STRING|"s = RoboTaskApp().expandtext(""{TextFile({TempDir}\\gendersize.dat)}"");"
line00000002=STRING|"//LogMessage(s);"
line00000004=STRING|"obj = JSON.parse(s);"
line00000006=STRING|"//LogMessage(obj.name + ""|"" + obj.gender);"
line00000008=STRING|"if (obj.gender == null)"
line00000009=STRING|"  {RoboTaskApp().SetUserVariable(""gender"", ""UNKNOWN"");"
line0000000A=STRING|"  }"
line0000000B=STRING|"  else"
line0000000C=STRING|"  {RoboTaskApp().SetUserVariable(""gender"", obj.gender);"
line0000000D=STRING|"  }"
linecount=STRING|"16"
savescript=STRING|"0"
Name=STRING|"Show ""Name: {name}"""
msg0=STRING|"Name: {name}"
msg1=STRING|"Gender: {gender}"
msgcount=STRING|"2"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"{TempDir}\gendersize.dat"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
Post by 5243 »
SUPER!!!!
:D
