Put variable value into the clipboard
rbtskrules
Post by rbtskrules »
Hi, I 'm starting with RoboTask and it is amazing what you can do with it. Every day I try to learn some function of this wonderful program . Although I need help on this occasion . As the title of the message, is not like going to clipboard
the contents of a variable ( which contains text ) . Could anyone tell me how i could do this . Regards, and thank you very much.
Re: Put variable value into the clipboard
Use Put Text action
See the example below
ExternalName=STRING|"Task26"
ID=INTEGER|1570703243
Name=STRING|"Put variable contents into clipboard"
Name=STRING|"Set variable ""MYVAR"" with value ""Hello World!!!"""
varname=STRING|"MYVAR"
varvalue=STRING|"Hello World!!!"
Name=STRING|"Put Text"
line0=STRING|"{MyVar}"
sourcetext=STRING|"1"
