How to delete identical lines
marcolobaido
Post by marcolobaido »
Hi, I need to delete all the identical lines from a text file except one.
I'm able to recognize the identical lines with the "if then" command, but i don't know how to remove them. I used STR Delete, but what does "source string" stand for?
CatID=INTEGER|317955339
ExternalName=STRING|"Task17"
ID=INTEGER|2123985992
Name=STRING|"Remove duplicates"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"1000"
external=STRING|"1"
filename=STRING|"C:\Users\Notebook\Dropbox\Cartsan\elenco mail ditte.txt"
linecount=STRING|"0"
linenum=STRING|"{LINE_NUMBER}"
variable=STRING|"EMAIL1"
Name=STRING|"Increment variable ""LINE_NUMBER"" di 1"
incement=STRING|"1"
vaiable=STRING|"LINE_NUMBER"
external=STRING|"1"
variable=STRING|"EMAIL2"
value1=STRING|"{EMAIL1}"
value2=STRING|"{EMAIL2}"
ActionID=STRING|"A_STR_DELETE"
Name=STRING|"STR Delete"
amount=STRING|"{StrLength{(EMAIL2})}"
from=STRING|"1"
source=STRING|"{EMAIL2}"
variable=STRING|"EMAIL_CANCELLATA"
Name=STRING|"Increment variable ""LINE_NUMBER"" di -1"
incement=STRING|"-1"
marcolobaido
Re: How to delete identical lines
Ok, problem solved! I used sort files and "remove duplicates" :roll:
This algorithm doesn't work.
See at the step #6
You have to remove email from source text (that is in the file: C:\Users\Notebook\Dropbox\Cartsan\elenco mail ditte.txt)
You can make this task very simple by using the action Sort Text
Also see my example below.
ExternalName=STRING|"Task19"
ID=INTEGER|1321482429
Name=STRING|"Remove duplicates (simple)"
ActionID=STRING|"A_FILE_SORTTEXT"
Name=STRING|"Sort Text"
assignvar=STRING|"0"
destfile=STRING|"C:\Users\Notebook\Dropbox\Cartsan\elenco mail ditte (sorted).txt"
savetofile=STRING|"1"
sortmode=STRING|"0"
sourcefile=STRING|"C:\Users\Notebook\Dropbox\Cartsan\elenco mail ditte.txt"
sourcekind=STRING|"0"
suppress=STRING|"1"
