Compatible with Server 2012 R2?
hongkwok
Post by hongkwok »
Is Robotask Compatible with Server 2012 R2?
I have tried the simple example "[DEMO] When Notepad Starts".
It works at win XP. But there is no response at Win Server 2012 R2
Is there something wrong?
Thanks
Re: Compatible with Server 2012 R2?
Yes, RoboTask is compatible with Windows Server 2012.
It seems the problem is that you try this task in service mode.
This task works properly in application mode within user session.
But RoboTask service works in separate SYSTEM session in OS Windows Vista/7/2008/2012
This is the property of operating system.
Read more about service mode here and here.
Also I recommend to read related chapters.
How to access RoboTask service in Vista+ systems: http://www.robotask.com/help/index.php? ... ervice.htm
