put a variable in file name
nikameto
Post by nikameto »
my process repeats itself every 2 hours and takes screens, so when i leave my computer on at night, when a screen is made, it overwrites itself, so i have come up with idea of putting a variable for example "count" and when the proccess finishes to increment it by 1 and file name will be screen{counter} and i will have screen 1 screen 2 , screen 3 screen 4 etc,
Re: put a variable in file name
You have to create global variable Counter with value 1
menu Options->Variables
Also see my example:
CatID=INTEGER|1416408852
ExternalName=STRING|"Task59"
ID=INTEGER|529022353
Name=STRING|"put variable into the filename"
ActionID=STRING|"A_SCR_SCREEN"
Name=STRING|"Screenshot"
captureregion=STRING|"0"
filename=STRING|"c:\temp\screen{Counter}.jpg"
format=STRING|"1"
Name=STRING|"Increment variable ""Counter"""
incement=STRING|"1"
vaiable=STRING|"Counter"
This task creates screenshots with number screen1.jpg, screen2.jpg and so on.
Screenshots are in c:\temp folder.
Also I recommend you to use screen name with current date-time like this
This expression generetes name like this:
The names always be unique and contain the date and time when they has been saved.
In this case you do not need to use any counters.
nikameto
Post by nikameto »
Oh my god this is super awesome. ROBOTASK IS THE FUTURE. :D :)
Thank you very much.
